B&W MT20, Mission M Cube or Other
Discussion in 'Home Cinema Speakers' started by cayman, Aug 25, 2006.
  1. cayman
    cayman
    Im looking at purchasing a Panasonic TH-37PX60 or Sony Bravia KDL-40V2000 with a Denon DVD-1920, Denon AVR-1906 which should look ok on a Alphason APX50/4-b stand.
    Looking to spend £500 - £1000 on speakers which will only be used for films as music is from separate system.
    Have read that B&W MT20, Mission M Cube, Kef 2005.2 are all highly recommended.
    Any advice on any of the above or other speakers would be appreciated.
    Ian
  2. PeteD64
    PeteD64
    Apr 9, 2006
    692
    28
    Southsea
    +48
    Another option along similar lines is the Anthony Gallo cinema setup for £850 - 5 Micro satellites & a TR-1 sub.
    I prefer them to the M-Cubes.
  3. Markster0
    Markster0
    May 4, 2003
    Of the 3, for the price, the Mission MCube would be my choice. The MCubes do not get the praise they deserve imo.
  4. Paul.B2
    Paul.B2
    Mar 3, 2002
    1,934
    63
    Buxton, Derbyshire
    +195
    You should also consider the Kef 3005 pack too. I considered all the ones you are, although i didn't demo the missions as when i saw them 'in the flesh' i didn't like the look of them.
    Kef 3005 & B&W MT-20 were very similar in movie performance, which was very impressive, but the Kefs were imo better for music.
  5. Wasabi
    Wasabi
    May 16, 2002
    1,188
    48
    SBC (Swedish Born Chinese)/lived in UK since 96, C
    +32
    A couple of others should be considered amongst the mentioned
    Tannoy Arena £1000
    MS Genies £525
    Monitor Audio Radius £980
    Mission M-cubes £800
    B&W MT20 £975
    Kef KHT-3005 £1000
    Kef KHT-2005.2 £500
    Spoilt for choice
    wasabi
  6. Markster0
    Markster0
    May 4, 2003
    The problem i came across with some of these packages - i need stands for the fronts so in the case of the B&W etc this adds another crazy £200 onto the price.
  7. Paul.B2
    Paul.B2
    Mar 3, 2002
    1,934
    63
    Buxton, Derbyshire
    +195
    Not quite £200 in the case of the Kef3005s. they are £120. :) Still far too much imho, but they are very good quality.
  8. cayman
    cayman
    Thanks for all the advice. I'm even more confused now with the extra speakers being recommended.
    Haven't heard of Anthony Gallo but have now requested a brochure.
    Over the next week i'll be out and about trying to demo some.
    Ian
  9. diggler46
    diggler46
    Nov 12, 2002
    1,050
    48
    Nottingham
    +46
    did you ever make a decision cayman?
