I auditioned both of these (the MT60D package for the M1's). I found the M1's less "boxy". Both driven by Yamaha AVR's. They are both still reasonably priced satellite speakers at the end of the day and I think this impacts the sound quality.Can anyone give thier opinions on the difference in sound and quality between these two B&W M1's Versus Monitor Audio MASS 5.1??
Many thanks for your replies.
Going to have a listen to MT50 package today.
Already heard the Radius 90 - sounded a little clerical to me but then I'm comparing with my home mission setup.
Always tricky when you can`t compare products head to head in same room with same material and with same receiver (similar what you have at home). That`s why i would try the head to head comparison (Audio-T has many shops) if possible. Demoing couple times is going to make you more certain that you are making the right choice, hopefully. So it wouldn`t be waste of time hearing them again later on if possible.
Anyway i hope you aren`t buying the subwoofer which comes with the MT50 or Radius package. There is better ones available for similar money / less, but you didn`t mention sub so i assume you will be using the one you got now.
Enjoy the demo and keep us posted!
