b&w m1
Discussion in 'Home Cinema Speakers' started by ovolv, Mar 3, 2013.
  1. ovolv
    ovolv
    Jan 30, 2013
    4
    Hi all, can anybody tell me when the revised m1 was released and or are there any visual changes to tell them apart? Cheers.
  2. Weetabix
    Weetabix
    Sep 30, 2005
    236
    Littlehampton, West Sussex
    +40
    Hi Ovolv,
    If I remember rightly, the most recent were released around Feb/March 2012.
    The Mark 1 versions, only had the grille covering the front of the speaker, and the cabinets has rubber tops and bottoms, the paint was a glossy finish too.
    On the new ones, the grille wraps from the bottom of the cabinet then over the front and covers the top, the base looks to match the finish of the speaker. The paint is a matte type finish.
    Hope that helps you.
    regards
  3. ovolv
    ovolv
    Jan 30, 2013
    4
    Brilliant, cheers, looks like I just purchased the mk1 version then! Doh, never mind. (Second hand I might add!)
