Rachit
Hello,
Before doing YPAO calibration, I did the sub setting to the following
Volume: slightly below midway
Crossover: as high as the dial will allow or set to the LFE setting if present
Phase: 0°
Auto power: disengaged and set so that the sub is permantly on
After calibration, at YPAO "Natural PEQ ", ypao selects bass cross over frequency to 60 hz
I wanna ask 3 questions
1)Is the 60HZ brass crossover frequency is the rt or shall i change it to 120 hz, I am confused,,,,will 60 hz setting at brass crossover will strain the M1?
2) which ypao equalizer setting is good for the above csetting, its has following options
ypao flat
ypao natural
ypao through
ypao front
Ypao Manual
3) which mode to use on Avr
Spectacle
dolby pro logic
neo:6
drama
straight
7-Channel
Thanks in advance
regards
Rachit
Phase: 0°
ypao flat
ypao natural
ypao through
ypao front
Ypao Manual
Spectacle
dolby pro logic
neo:6
drama
straight
7-Channel
Thanks in advance
regards
Rachit
