I have four mk2 M1, all four mid bass drivers are fraying. I am sure there is a manufacture flaw on this. Mine are being sent B&W and they mentioned this was the first time they heard about this.
For all M1 mk2 owners please check your mid bass drivers.
You will never know by listening if speakers are set to small or crossover set to 80hz. Or if it's early stages of fraying.
Test them out by setting them as Large speakers or in Full range.
If you have faulty drivers the bass will sound muffled.
Or use torch and inspect the drivers
Hope this helps someone
