B&W LCR60 Vs LCR600
Discussion in 'Home Cinema Speakers' started by trenery, Jul 31, 2005.
  1. trenery
    trenery
    Jul 19, 2005
    5
    Does anyone know if the LCR600 is much better than the LCR60?
    Should I be looking at any other centre speakers.
    Mike
  2. recruit
    recruit
    Do you have existing 600s3 range of speakers if so then either of the 2 mentioned Centre speakers would be a good match but the bigger model would be more suited to the 603s3 & 604s3 speakers, also it is a good idea to keep the front 3 speakers of the same make as they then tonally match.
    Regards
    John
