B&W HTM7
Discussion in 'Home Cinema Speakers' started by SKA.face, Jan 1, 2005.
  1. SKA.face
    SKA.face
    Hi there!
    Anyone using one? any thoughts on it? currently using a Kef egg,and want to replace it with something more than a glorified TV speaker.Will be using either B&W P6 or 804 as fronts,thought about the HTM2 nautilis,but don't think a Pioneer 912 will be good enough for it,so wonderd what people thought on the HTM7?
    Thanks.
  2. monkeyboy69
    monkeyboy69
    Mar 30, 2002
    589
    +11
    I've heard this hooked up with 704's and the ds7 and the front sound stage was excellent. we then substituted an lcr600 and the difference was night and day. the htm7 was far more detailed.
    Hope you've got a lot of room though because its huge which is its only drawback IMO
  3. SKA.face
    SKA.face
    Thanks MB69,yes,its rather large which isn't in its favour,should hopefully be putting it in a 3.2m x 5m room,so hopefully big enough.
