B&w Htm2
Discussion in 'Home Cinema Speakers' started by Gliese 581c, Mar 1, 2003.
  1. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,757
    On AVForums
    +569
    Could anyone with the B&W HTM2 center channel speaker please give me a little advice.
    Up untill yesterday I used bare wire to connect to the speaker. Now I have new speaker cable (nordost super flatline gold) with 'z' plugs.
    there's no cap on the binding posts so that i may fit the 'z' plug.
    can anyone help ?
  2. warrj
    warrj
    What's a 'z plug'? Is it like a banana plug?
    I believe that in order to use banana plugs with Nautilus speakers you have to snap a piece of plastic out. I've always been too scare to attempt it so I haven't used plugs.
    Regards,
    Jules.
  3. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    It's Nordosts version of a banana plug. Works in the same way.
    To answer the question, all B&W speakers have removeable plugs/bungs in the tops of the binding posts. The z plugs will be fine.
    They are pretty easy to remove if you use a small metal pick, or are carefull with a Stanley knife you can ease them out.
  4. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,757
    On AVForums
    +569
    Weird though, they are flush with the protective plastic sheliding as if its not meant to be removed.
    I'll do it now, thanks for the help :)
  5. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    Funny that.:D
    (They definately will come out though).:clap:
  6. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,757
    On AVForums
    +569
    sorted :smashin:
    cheers
