B&W HTM
Discussion in 'Home Cinema Speakers' started by Kobus, Mar 25, 2005.
  1. Kobus
    Kobus
    I will be using 803's in the front of a 7m x 4m room.
    Is the HTM3 wirth the extra money over the HTM4 ?.
    Obviously I imagine it to be better, 3-way etc., but is it worth it ?.
  2. recruit
    recruit
    Definitly it will then match you're 803's perfectly ;)
    The front 3 speakers should be of the same quality as the HTM4 is designed to work with the 805S's.
  3. rags
    rags
    Apr 13, 2003
    4,127
    London
    +323
    Yup - exactly what Recruit said above. Dont mix the 803S speakers with a HTM4 unless there are severe budget / space restrictions.
  4. Kobus
    Kobus
    Thanks for the help,
    I like the way you state "severe" budget restriction. That is an interesting concept for most of us.
  5. rags
    rags
    Apr 13, 2003
    4,127
    London
    +323
    It is but hey you only live once ! I noticed you have the N803 model - in that case you should really try and get a ex dem / second hand HTM1 - will save some money as well from buying a new HTM3.
  6. recruit
    recruit
    One thing i would add though Kobus is that the HTM4 is an excellent Centre speaker and just as good as my 805S's but i would follow what Rags has said and maybe try and source a HTM1 if budget is tight as that would be a better match for you're 803's.
