Wanted B&W HTM 4 or HTM2 Diamond in Cherry
Discussion in 'Archived Classifieds' started by JW Noorda, Apr 3, 2016.
  1. JW Noorda
    JW Noorda
    Feb 9, 2014
    244
    London
    +7
    As per the title, looking for a B&W HTM 4 Diamond in Cherry.
    ______________________________________________________
    This message is automatically inserted in all classifieds forum threads.
    By replying to this thread you agree to abide by the trading rules detailed here.
    Please be advised, all buyers and sellers should satisfy themselves that the other party is genuine by providing the following via private conversation to each other after negotiations are complete and prior to dispatching goods and making payment:
    • Landline telephone number. Make a call to check out the area code and number are correct, too
    • Name and address including postcode
    • Valid e-mail address
    DO NOT proceed with a deal until you are completely satisfied with all details being correct. It's in your best interest to check out these details yourself.
  2. TomScrut
    TomScrut
    Jan 11, 2012
    2,654
    Scarborough, UK
    +434
    Might be worth you considering the SCM1 or SCMS depending on whether you can wall mount stuff. They are generally cheaper than 805s of the equivalent age but are more or less the same speaker. They are a lot rarer too though.
  3. JW Noorda
    JW Noorda
    Feb 9, 2014
    244
    London
    +7
    Thanks Tom for your suggestion. Unfortunately I do not have the option for wall mounting, so it will have to be a bookshelves on stands.
    How do you like playing with the HTM4s as centre? Have you ever considered the HTM3s? Or the HTM 2 Diamond?
    I'm still a bit in between the 2 and 4 Diamond, but with twice the price not sure if the difference is worth it.
  4. TomScrut
    TomScrut
    Jan 11, 2012
    2,654
    Scarborough, UK
    +434
    My sig must be out of date! I am only on stereo nowadays. The HTM4S is all I could justify spending at the time, but the CT7.3 I had as a centre afterwards was better. Full range sounds so much better IMO on centres. The HTM4S wasn't bad but I bet a HTM3S, HTM2D, HTM1D or HTM2 Diamond would be a lit better
  5. JW Noorda
    JW Noorda
    Feb 9, 2014
    244
    London
    +7
    bump, would consider a B&W HTM2 Diamond as well
