b &w help !!!!
Discussion in 'Home Cinema Speakers' started by jason t, Nov 17, 2003.
  1. jason t
    jason t
    Mar 4, 2001
    1,569
    48
    kent
    +38
    please help i need some advice !!!
    i currently have 2 x b&w 603 s3 front lcr600 s3 centre and two vm1's rear i also have a asw675
    i am thinking of selling the lcr600 centre due to the size,( finding it hard to position) and i was wondering what a vm1 would sound like as the centre with the 603's do you think it will be a miss match??
    i did consider going for 5 vm1's but i dont think they would sound as good with music as my 603's
    thanks
    jason
  2. ELV
    ELV
    Jun 5, 2001
    663
    Up in the proper north
    +9
    Try swapping them to find out????
  3. jason t
    jason t
    Mar 4, 2001
    1,569
    48
    kent
    +38
    yeah i will have to try !!trouble is nothing is connected at the moment changing my front room around try it to get it as neat as possible
    jason
  4. monkeyboy69
    monkeyboy69
    Mar 30, 2002
    589
    +11
    jason - are you looking to sell your lcr600 on? I've been after one lately
    pm me , if you're interested - cheers
  5. zoolander
    zoolander
    The LCR600 is an awesome centre speaker,with identical mid/bass unit as your 603s3.Visually they are a perfect match too!It would be silly to replace it with a VM1 as it will no doubt be sonically inferior to the lcr600.Do you place the centr speaker above your TV?Most TVs can accomodate centres of that size,just blu tack it down to the top of the TV set!If you must downgrade,then go for the LCR60 which uses smaller 13cm drivers but the LCR600 is definately the best match.
    Zoolander:D
  6. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    I had my LCR600 on a 24" TV. :D
    MuFu.
  7. zoolander
    zoolander
    I like your style!Bet your TV cost less than that beast of a centre speaker too!
    Zoolander:D
  8. danfrance110
    danfrance110
    Fancy swapping my lcr60 in sorrento for your 600 plus some cash?
    Dan
  9. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    Wasn't my TV but probably, yep.
    [​IMG]
    :eek:
    MuFu.
  10. zoolander
    zoolander
    :eek: nice! whos TV was it:confused: good job its magneticaly shielded ay:D
    zoolander:D
  11. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    My folks'. Was going to get my own but ran out of money and dropped backed to just a 2.1 setup for uni.
    It's a fantastic speaker. I doubt you'll be satisfied using a VM1 instead, Jason.
    MuFu.
  12. jason t
    jason t
    Mar 4, 2001
    1,569
    48
    kent
    +38
    well getting a plasma so that rules out putting it on top!!!
    if you think i am mad getting rid of it for a vm1 my only option is to wall mount my plasma which could be a pain due to plasterboard walls :(
    sorry monkeyboy looks like i will keep it
    jason
  13. monkeyboy69
    monkeyboy69
    Mar 30, 2002
    589
    +11
    damn , fair enough jason
    wise choice though top speaker
  14. corh5
    corh5
    Feb 6, 2004
    535
    +13
    Hi Jason
    What are the VM1's like as rear speakers complimenting the B&W 603s at the front... I'm thinking of doing a similar setup but i have B&W 601s.
  15. jason t
    jason t
    Mar 4, 2001
    1,569
    48
    kent
    +38
    well personally i think they work well, i am pleased with mine and think they look much nicer in black
    jason
