raphaelchang
Hello,
I am planning to purchase a set of B&W DS3 speakers for my side channels. However, the area I am planning to mount it has a door frame too high to fit the speakers' height. I want to know how far the wall mount brackets of the DS3 stick out from the wall and how far they are from the bottom of the speakers, so I can see if the brackets will extend the speaker past the depth of the door frame so that I can fit it. Please view the attached image for a diagram. Thank you very much for your help.
