B&W DM601 S2 - BLOWN
Discussion in 'Home Cinema Speakers' started by Vigour, May 21, 2005.
  1. Vigour
    Vigour
    recently blown ONE of my b&w dm601 s2 speakers now it just rattles i think its the speaker cone as it sounds like its rubbing when i move it.
    Does anyone know if its possible to get this repaired? and if so how? and how much.
    need to know asap please :eek:
    :( thx
  2. Vigour
    Vigour
    I think the coil has snapped inside the speaker. Is there a way of gettin this fixed?
    If not the replacement part for it is ZZ11428 how can i get another?
  3. Miniholic
    Miniholic
    Apr 26, 2001
    3,046
    The Shire
    +398
    Have you tried contacting B&W? They are usually very good at providing replacement parts, and the prices are lower than you might expect.
  4. Vigour
    Vigour
    Thanks - Going to give them a ring monday, offices are closed weekends. :)
    How much do you reckon it's going to cost? its the whole cone/speaker bit i need. i dont have the slighestest idea
