B&W DM600S3 or Kef Eggs?
Discussion in 'Home Cinema Speakers' started by Vodder, Jan 11, 2004.
  1. Vodder
    Vodder
    Jan 11, 2004
    449
    16
    London, UK
    +8
    I am currently looking at getting the following B&W setup:
    DM602 S3 for front
    DM601 S3 for rear
    DM600 S3 for rear centres
    LCR60 S3 for front centre
    ASW300 or ASW 600 for sub
    Would anyone recommend this setup - I want it for AV use and music, mainly dance type stuff - or anything else?
    I have looked at the Kef eggs - although brilliant with AV - I thought maybe somehting was lacking music wise?
    Any thoughts on this?
    Cheers,
    Tim
  2. gpa
    gpa
    Demo kef q7/q5's and the q9c and the new wharfdale range
    cheers
  3. Vodder
    Vodder
    Jan 11, 2004
    449
    16
    London, UK
    +8
    Cheers, those Kef's are a little out of my price range.
    Which Wharfedale's did you mean, the Diamond or Pacific evolution range?
    Would you not recommend the B&W setup?
  4. onefivenine
    onefivenine
    Nov 5, 2003
    3,353
    Edinburgh
    +616
    I've got a similar B&W setup (as per sig) minus the centre-rears and sub. I have never been disappointed by the sound on either movies or music.
    Getting a sub soon and was thinking of a B&W ASW675. I have also been recommended a REL Q150E which looks like it might be better for my setup, for switching between hi and lo level inputs.
  5. Warpaint
    Warpaint
    Jul 26, 2003
    597
    28
    Edinburgh
    +62
    You will be hard pushed to find a better solution than the B&W's. Consider listening to the same system with 601's at the front, or even the rear centres. Thes have a very similar character to the LCR60 and the subwoofer can be used to tune the bass performance. (get the ASW600)
