B+W centre, VM1 or LCR60-S3 ?
Discussion in 'Home Cinema Speakers' started by ranger1873, Nov 26, 2004.
  1. ranger1873
    ranger1873
    I'm looking for a new centre speaker to go with my DM601-S3's.
    The book says lcr60-s3 but this is a BIG unit and the vm1 looks the part with the TV :rolleyes:
    has anyone heard the vm1 with the dm601's?
    i need to know if the sound matches well. they should be as they are the same (B+W) ...
  2. recruit
    recruit
    The drive units are not the same so they may not Tonally match each other if you can it is always better to keep the front 3 channels the same!
    John
