B&w Center
Discussion in 'Home Cinema Speakers' started by mconn, Aug 2, 2002.
  1. mconn
    mconn
    Feb 5, 2002
    185
    +6
    After a long time have brought B&W 602 s3 for front and rear.
    Need to decide on a center.Would the lcr 60 or the lcr600 suit the 602 better.Any thoughts appreciated.
    mconn
  2. OnTheFly
    OnTheFly
    Jul 2, 2002
    3,038
    83
    Everywhere
    +123
    You should really buy the LCR 60 S3 mainly because it is the most up to date model. Also, I happen to own one that is for sale. Mine is less than 1 year old with all documentation and original packaging.
    Don't miss out.:rolleyes:
  3. GJC
    GJC
    Mar 1, 2002
    2,142
    London
    +69
    MCONN
    B&W recommend the DM600 to be used with the DM602.5 (which is smaller in sound to your DM602's)
    So the DM600 would probably integrate better - try them both.
    Regards,
    GJC
  4. mconn
    mconn
    Feb 5, 2002
    185
    +6
    HI,
    Thanks for the reply guys.I think the 600 will have to get a listen.
    For the price difference i wonder if it worth it?
    Anybody have the same setup?
    Thanks,
    mconn
  5. GJC
    GJC
    Mar 1, 2002
    2,142
    London
    +69
    MCONN
    I use the 600 with my 603s2's and it sounds awesome. For me its worth the extra £'s.
    GJC
  6. dfield2000
    dfield2000
    Jul 16, 2002
    957
    Cardiff
    +5
    I bought a 60 centre to with my front 603s. The main consideration for me was the size. The 600 centre is quite a large speaker - I recommend checking the dimensions first.
  7. mconn
    mconn
    Feb 5, 2002
    185
    +6
    Thanks for all the info guys.
    Will have no problem with space.
    Think i might go for the 600.
    mconn
  8. Doug
    Doug
    If you're still undecided...
    I had the 60 while waiting for my 600 - it's definately worth the extra IMO, especially for PL2 which places a lot of emphasis on the centre speaker
    I have pictures of both in my setup if you want to compare sizes
    Doug
