B&W CDM NT Series question
Discussion in 'Home Cinema Speakers' started by GavinH, Oct 30, 2003.
  1. GavinH
    GavinH
    Sep 22, 2003
    122
    16
    Newcastle
    Hey all, just wondering if someone could answer some questions about the CDM NT series.
    I know this line has been discontinued, but does anyone know how much:
    - a pair of CDM 9NTs used to cost
    - a CDM CNT used to cost
    - a pair of CDM SNTs used to cost?
    I understand the CDM 7NTs used to retail at 1250.
    Also, if anyone has heard some combination of this series in an AV system, I would be interested to know if you feel a sub is essential? Of course that may be dependant on which speakers in the series are used :D
    Cheers,
    Gav
  2. mjn
    mjn
    May 24, 2001
    21,403
    Herts, England
    +8,958
    9NT's £1850, CNT £400 and SNT's £750
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,556
    Edinburgh
    +1,265
    Sorry slight correction to above prices.
    CDM9NT: £1800
  4. GavinH
    GavinH
    Sep 22, 2003
    122
    16
    Newcastle
    Thanks guys,
    mjn - do you have a sub in your surround system?
    Gav
  5. p.booth
    p.booth
    Oct 8, 2002
    3,983
    mbro
    +145
    check out my signature .!! :D
  6. Lefreck
    Lefreck
    Mar 27, 2002
    75
    L
    I use a CDM System:
    Front: 2 CDM9NT
    Center: CDMCNT
    Back: 2 CDM1NT (not yet installed:blush: )
    Sback: Boston Ac. VRS PRO
    Sub: B&W AS3000
    I bought the sub before I had any CDM-speakers, because I intended to buy a couple of N805s. I think that, with CDM9NT, one could live without a sub for a while...
  7. mjn
    mjn
    May 24, 2001
    21,403
    Herts, England
    +8,958
    no sub as yet, but looking at the CDM sub at the moment!
  8. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    I have - could you try and condense it onto two or three lines please. Thanks
  9. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,671
    Gavin...for that sort of budget,you should also have a look at the Nautilus 805's,which,whilst being a bit bass-light in comparison with the CDM9NT are a much clearer speaker(IMHO of course!)and with suitable amps also have a surprisingly good bass extension.
  10. budvarholsten
    budvarholsten
    Dec 12, 2002
    59
    UK
    I've got the nt package, using the 9nt's at the front and have found them to be exellent. Clarity is bordering on scary, midrange is superb, however I have found that a sub is essential.
    When I first got them, I was initially disapointed as I didn't have a sub, and they took a fair bit of running in. Once I got my sub though, and after they had been properly run in I loved them.
    I tried a couple of subs that are worth an audition. The M&K MX350 was good but uglier than a bull dog chewing a wasp. The Rel Stentor III was good but as I have a big room the volume had to be turned up pretty high to be effective, but the problem with that was you could start to tell where it was coming from.
    In the end I opted for a pair of cheaper Rel Stadium III's and am really impressed.
    So I would say get the CDM 9NT's, but definetly get a sub or even two smaller subs to go with them.
