B&W CDM 1 SE and ARCAM sounds HARSH? WHY?
Discussion in 'Arcam Owners' Forum' started by STIFA, Jun 9, 2005.
Tags:
  1. STIFA
    STIFA
    So my systemis as follows:
    Arcam Alpha 8r integrated
    Arcam alpha 9p power amp
    Arcam alpha 8 CD Player
    B&W CDM 1 SE
    VanDenHul CS-122 speaker cable with D-102 mk3 interconnects
    Sound has brutal resolution and dynamics but it is hard on the ears , highs are harsh ,
    It lacks a bit of warmth too.
    I bought all of these used from a friend, but I was told that it takes some time for components to mix together (BURN-IN)
    ??? TRUE??
    What is the problem? should I change to new cables and which?
  2. Hifi addict
    Hifi addict
    well, both the CS-122 and D-102 are not the best in the high frequencies. They both tend to overdo the high notes. I would also expect that your voices are a little bit "tight" or "small".
    Try some other speakercables 1st (whatever you can get your hands on)
  3. radio
    radio
    Jun 1, 2005
    246
    Toronto, Canada
    +5
    I agree. Finding a speaker to your liking which may not be liked by others or may not be approved of others...
    I find most brands out there to be very harsh.. polk.. paradigm... psb image series... i found the AE Aesprit series to be not so bad...
    but its all dependent on what you prefer...
    i am anti-harshness and arcam in its class has little or no harshness if paired with fitting speakers.
