meep
Hi There,
I attended a Hi Fi show today and had the opportunity to audition several speaker packages for home cinema application.
I was blown away (literally!) by the B&W range, CDM-NTs in particular.
I had not considered these as they are beyond my budget but I am now seriously considering purchasing a set in stages.
That being the case, I wonder if forum members might advise on which of the following options would give me the best immediate user experience as I form the basis for future expansion. In the cases of option 1&2, it would probably be 4-6 months before I could add to the basic l/r/c purchase.
OPTION1
2x CDM 1NT (to be used as l/r fronts)
1x CDM CNT
Subwoofer (make & model to be determined)
At a later date, I would add CDM 7NTs and move the 1NTs to surround positions.
Later again, a pair of CDM SNTs to be added as rears
Immediate Cost: 2,600 approx.
Complete Package Cost: 6,000
I see this a a good starter, building to great system. The principal question is, will the 1NTs hack it as cinema fronts in the short term?
OPTION2
2x CDM 7NT
1x CDM CNT
No subwoofer
At a later date, 4x CDM SNTs added as surrounds
Later again, a subwoofer
Immediate Cost: 2,800
Complete Package cost: 5,800
Will the 7NTs work well in the short term without a subwoofer?
OPTION3
2x DM603 S3 Fronts
1x LCR600 S3 Centre
1x Subwoofer (make & model to be determined)
At a later date, 4x DM601 S3 to be added as surrounds
Immediate Cost: 2,300
Complete Package Cost: 4,000
A step down from the CDM-NT series. Will I always regret it?
OPTION4
2x DM602.5 S3 fronts
1x LCR600 S3 centre
4x DM600 Surrounds
Subwoofer (make & mode to be decided)
Immediate (& total) cost: 3,200
A full system, within my current budget. No waiting but what's the compromise?
These speakers will be driven by a Pioneer VSK D-2011 Amp. Here are the basic specs;
Power Output DIN 7x100W (1kHz, THD 1% and 8?)
Power Output RMS (2 channel mode) 2x100W (20Hz - 20kHz, 0.09% and 8?)
Frequency Response Line: 5 -100,000Hz (+0dB and -3dB)
S/N ratio (IHF-A) Line: 92 dB
Electrical power consumption 600w
Weight 19.6kg
As B&Ws apparently need lots of power, will this unit provide enough "grunt" for each of the above?
I have a large room(18' wide x 22' long). In all cases, I can use my current cheapie panasonic speakers as surrounds/fill ins until I can afford the additions outlined.
All advice appreciated. I'm kind of smitten by the B&W range now that I've heard them (in comparison to other on display), but pointers to other alternatives would not go amiss.
Regards
Peter
OPTION1
1x CDM CNT
OPTION2
2x CDM 7NT
1x CDM CNT
No subwoofer
OPTION3
2x DM603 S3 Fronts
1x LCR600 S3 Centre
OPTION4
1x LCR600 S3 centre
4x DM600 Surrounds
Weight 19.6kg
Regards
Peter
