B&W ASW675 or Rel Stampede
Discussion in 'Subwoofers' started by Papereyes, Dec 22, 2004.
  1. Papereyes
    Papereyes
    Nov 29, 2003
    33
    +5
    undefined
    Hi there
    Having decided to go for a Subwoofer for my system, i've decided between 2 and I am now stuck for choice between the B&W ASW675 or Rel Stampede.
    I currently have B&W 603 for Left and right with LCR 60 for centre.
    Does anyone have any opinions?
    Lai
  2. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,078
    notts.
    +63
    Will it be for movies and music,The asw675 is a excellent little sub and would outperform the rel with movies but with music the rel is a bit more flexible as you can run both high level and low level connections where on the asw675 you just have a low level connection,I have owned the asw675 and can vouch for its performance.If size isnt important you can pick up a svs tower for the same price and it will really give you what you are after clean powerfull bass,
    Cheers Gonzo. :)
  3. Papereyes
    Papereyes
    Nov 29, 2003
    33
    +5
    Hi there Gonzo
    I'm mainly using it for movies, with the occasion use for music.
    How does the 675 work for music? and the stampede with movies?
    Lai
  4. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,078
    notts.
    +63
    The rel i owned was easier to set up (intergrate) with music, the asw675 was more difficult but with careful setup sounds very good it just takes longer.The asw675 is very powerful for its size and easily beat the rel with movies on slam and depth,The only thing i would say is give it a bit of space in its firing line and iam sure it will get you grinning.
    Cheers Gonzo.
  5. Kazman
    Kazman
    Jan 14, 2004
    5,266
    Luton, Bedfordshire
    +139
    For the money you are spending, I'd serieously look at the Quad L Subwoofer, will do both music and movies proud, in my opinion, I believe it is a few steps ahead of the Stampede and the 675, and only costs a tiny amount more. It also looks nicer :D
  6. recruit
    recruit
    Agree with Kazman the new Quad sub is definitly worth considering aswell.
    John
  7. ScottW75
    ScottW75
    Feb 5, 2003
    4,156
    +702
    I got a demo of the 675 and the quad L series, and agree that it sounds a lot better.
    So much so there's a quad L series in the corner of my livingroom now!!
  8. Kazman
    Kazman
    Jan 14, 2004
    5,266
    Luton, Bedfordshire
    +139
    It's so hard being right all the time :D :rotfl: :cool: j/k :)
  9. Papereyes
    Papereyes
    Nov 29, 2003
    33
    +5
    Thanks for the comments guys, looks like another one to add to the list when i go and demo.
  10. 30CenturyMan
    30CenturyMan
    Dec 3, 2004
    760
    +47
    The Mordant Short 909W seems to get a lot of good reports too. :)
  11. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    Is that the one that I have been recommending as an unsung subwoofer hero since February :rotfl:
  12. 30CenturyMan
    30CenturyMan
    Dec 3, 2004
    760
    +47
    So you say! :D
  13. Kazman
    Kazman
    Jan 14, 2004
    5,266
    Luton, Bedfordshire
    +139
    The 909 is a great subwoofer aswell, but after hearing what the Quad L sub can do, I'd say it is the better buy, mind you, the Quad is £200 more expensive rrp, so it should be better.
    The 909 is one of the subs featured in the budget sub test, a sticky of which can be found at the top of this very forum :D
