b&w asw 675 sub
Discussion in 'Subwoofers' started by malariaboy, Feb 8, 2003.
  1. malariaboy
    malariaboy
    Dec 16, 2002
    1,865
    taunton somerset
    +120
    has anyone got one and what are your opinions on this sub. any help would be much appreciated
  2. Apocalypse
    Apocalypse
    Aug 14, 2002
    840
    19
    Sheffield
    Do a search for the username "Apocalypse" and the keyword "asw 675" :)
  3. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,078
    notts.
    +63
    Hi Malariaboy
    I have a asw675 sub which i upgraded from the relq150e .The sub is very potent with music and movies the reason i chose this sub was for its size looks{waf} and its power. It is a very capable sub for its size But if you could accommodate the velodyne cht15 you will get a better performance has it is a much bigger sub with a 15'' driver which is servo controlled.I would have had one if i had got the room but i havent so the asw675 is my compromise a very good one though.
    regards Gonzo.
