b&w 825/865 or velodyne dd-10/12
Discussion in 'Subwoofers' started by ihan, Jul 5, 2005.
  1. ihan
    ihan
    Sep 10, 2004
    655
    28
    Stockport
    +25
    I have just purchased a set of B&W 804S and would like to enhance the bass for music with a subwoofer. My options seem to be:
    1. B&W 825 (available now) - this has no room eq.
    2. B&W 865 (not available yet due September, basically this is the 825 with room eq).
    3. Velodyne DD10 or 12 with room eq(already available).
    HT performance aside (I don't really care about this), which of these subs is likely to musically integrate best with the 804S? Is the room eq feature useful, or is it just marketing hype. I have heard people say (on a velodyne forum) that equalising for a flat resonse does not give the best musical results.
    Any advice would be much appreciated.
    Regards,
    Ian
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    At least one forum member has said that his Velodyne DD-10 sounds better with the room equalisation switched off.
  3. 30CenturyMan
    30CenturyMan
    Dec 3, 2004
    927
    46
    +117
    Ian,
    If you're refering to Jeff, I think he has a DD-12. He has mentioned a preference for non-EQd bass a few times.
    Bass is a strange one, especially very low distortion bass - some people think it lacks impact and would prefer a bit more distortion. The only way to be sure is to demo a few different contenders (preferably in your room). :)
    **Edit**
    What about the B&W ASW850 in the classifieds section? I would seriously consider that if I were looking at buying a B&W subwoofer.
  4. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    I was, but what's a couple of inches between friends.
  5. recruit
    recruit
    If you have a dedicated room with acoustic treatments then EQ is probably not needed but if you are like the majority and the room has not been treated then the EQ facility can have a dramatic effect on the in room response and improve performance.
  6. ihan
    ihan
    Sep 10, 2004
    655
    28
    Stockport
    +25
    Many thanks for the replies so far. I've decided to go for a discounted (<£2k) Velodyne DD-12. I don't know if this will be better than the B&W series, but I feel more comfortable buying it because of its adjustment facilities. For instance, you can alter the phase in 15degree increments, which you cannot do with the B&W.
    I'm also thinking that the EQ facility may be useful if I am getting 'one note' bass as a result of room modes?
    Add to that the distortion reducing servo, I have come to the conclusion that the Velodyne has higher tech electronics, whereas the B&W is a very high quality drive unit coupled with bog standard electronics.
    Regards,
    Ian
  7. 30CenturyMan
    30CenturyMan
    Dec 3, 2004
    927
    46
    +117
    That's some conclusion! :D
