b&w 603 s3 and wiring..?
Discussion in 'Home Cinema Speakers' started by smargi, Jul 27, 2005.
  1. smargi
    smargi
    May 22, 2005
    62
    i see alot of wiring cable out there and with all kind of thikness i like to know what is the correct way to connect a speaker and what is the difference between the top connection of the speaker or the bottom of the speaker...?
  2. Troon
    Troon
    Apr 28, 2005
    151
    The two sets of connections are to allow bi-wiring or bi-amping: one set is for the HF (high frequency) units, one for the LF (low frequency).
    You don't need to do that, though. Get some decent multi-strand thick copper speaker cable, and connect the positive (red) output of the amp to one of the positive inputs on the speaker, then use a short length of cable (or the bars B&W provide) to join to the other positive binding post. Do likewise for the negatives.
    Note that the cable need not be expensive. Speaker cable, contrary to what high-end manufacturers will tell you, is not rocket science. A good basic starting point is QED 79-strand or equivalent. I don't believe anyone can tell the difference between that and any other properly-made cable in a blind test.
    Keep the cable lengths as short as you can - don't go crazy on this, but avoid having redundant coils of it hanging around. You'll hear advice to keep the lengths the same: this is nothing to do with timing, but is to try to match the resistances. For decent cable, this is not very critical at all.
    Hope that helps.
