B&w 601S3 as Rears
Discussion in 'Home Cinema Speakers' started by cracken, Sep 28, 2003.
  1. cracken
    cracken
    Jan 21, 2001
    1,222
    colchester
    +39
    anyone use these as rears, what are your general comments
    (to be powered by a demon 3801)
    also whats a good price for these speakers as a pair?
    thanks for any info.
  2. magking
    magking
    Jan 6, 2001
    378
    Norway
    I use them as rears and they do a good job:clap:
    I have a Denon AVC A11SR, but the 3801 have power enough to drive them with no problem.
    Can't comment on prices as I live in Norway.
  3. mick23
    mick23
    Mar 20, 2002
    801
    uk
    otv i use 600s3 as surrounds with 3802 find them ok.
    moorgate accoustics have pair of 601s3 for about £129 if i recolect properly.
  4. cracken
    cracken
    Jan 21, 2001
    1,222
    colchester
    +39
    cheers for the advise peeps, will call moorgate :)
  5. nathan_silly
    nathan_silly
    I use B&W 601's- I would recommend at least comparing bipoles/dipoes/tripoles as well as the 601's, especially if the side & rear speakers are close to the sofa.
    I'm thinking of replacing my 601's to some bipoles.
  6. cracken
    cracken
    Jan 21, 2001
    1,222
    colchester
    +39
    ive got some mission 77DS at present, and dont like the way they are positioned next to the sofa, wanted some bookshelf type for the rear corners of the room.
  7. Miniholic
    Miniholic
    Apr 26, 2001
    3,045
    The Shire
    +398
    I use 601s3's as surrounds and they are great, they are quite near to the listening position (about 1.5m @ head height) but are never intrusive. I've never tried di/bi-poles other than at the dealers though, so can't really compare the two in the real world.
    I run mine with a 3802, with 602.5's and an LCR60 up front.
    Hope this helps.
    Ian
    ian @ miniholics.co.uk
  8. Mogli
    Mogli
    Feb 25, 2003
    764
    43
    +124
    Hi.
    I also use 601's as my rears. They sound good imo. Though as others have said it could be an idea to have a listen to some bipoles or ttripoles and see what you think.
    I currently have them running with a 2011 a pair of Cdm1's and CdmCnt and they integrate nicely.
    Cheers,
    Hus
