We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
B&W 601 S3 vs LM1 - Bass performance?
Discussion in 'Home Cinema Speakers' started by BenW, Oct 30, 2005.
  1. BenW
    BenW
    Jun 3, 2005
    888
    Stansted
    +17
    I know these are both deigned to be used in different ways but i've been looking at 601s then saw the VM1s and they're going to fit in the room much better
    The question is, will the 5" driver on the VM1s be enough? Think they're really designed to be used with the AS1 sub but money doesnt allow for that.
    Should also add here, are the 601 S3 suitable for use near a tft pc monitor?
    Ben
  2. pragmatic
    pragmatic
    Nov 9, 2004
    12,156
    +1,647
    Magnets don't effect TFT's so no worry about interfierence.
  3. conkerman
    conkerman
    Feb 21, 2005
    494
    28
    +39
    You will have to have a sub with the LM1, VM1 or M1. as the combinaion of small drivers and low cabinet volume mean very little bass. Look at the specs, you will probably find that the low frequency respose only starts from 80Hz or so.
    The 601 is designed as a full range speaker so will probably sound better if used without a sub.
    Horses for courses I'm afraid.
  4. BenW
    BenW
    Jun 3, 2005
    888
    Stansted
    +17
    Thanks, quick question...
    I really do love the depth of a subwoofer, the one on my pc apparently goes down to 35Hz.
    The B&W 601 S3 claim 60Hz
    Is this a big difference or not? The sub on my pc speakers isn't too bad, would like to have something similar in performance
