Originally posted by brokebloke
Does anyone know if the tweeters in the B&W 603s2 are the same as in the 601s2 . The tweeters in my 603,s have been pushed in and i was wondering if i could just use the ones out of my old 601s2's .
Actually, no they aren't the same.
The S3s supposedly have a redesigned (by how much I'm not sure) tweeter to extend high end response for DVDA/SACD.
Whether this will equate to any real audible differences though, I don't know.
The thing is, just because it looks very similar/the same, doesn't mean it is the same - it could have very different properties. Then again, it could have virtually identical properties too.
I guess only B&W will be able to tell you for sure - but if they are sufficiently different, some crossover reworking may be necessary to get things spot on.
You need to know a few things (there's more to it, but from a replacement perspective, you can probably get away with knowing just the following)
Are the sensitivities the same?
Is the impedance the same?
Is the low end roll off similar?
Three "yeses" to those questions, and you'll "probably" not be able to tell any real difference!
