B&O and Hitachi plasma
Discussion in 'Plasma TVs Forum' started by bonzo500, Jun 29, 2004.
  1. bonzo500
    bonzo500
    Has anyone connected a B & O Beosound 9000 to a plasma???
    Im getting my Hitachi pd5300 and would like to use this with my Beosound 9000 connected to 2 beolab 4000 speakers.
    Any help would be highly appreciated!!!!
  2. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    The BeoSound should have an AUX input (pair of RCAs) which will match up to the Hitachi's Audio output on the back of the media box. Just need a decent stereo audio cable.
  3. bonzo500
    bonzo500
    thanks Liam,
  4. timetraveller
    timetraveller
    Jan 11, 2004
    50
    11
    Bournemouth
    +4
    My 9000 had a 7 pin din for aux (5 pin din will work as well) and I purchased a cable with 2xRCA phono to 7 pin din plug to connect my TV and then just choose aux on the Beo4 remote to play that source through your speakers.
    Only possible if speakers are active as 9000 doesn't have an amp. My speakers are the Beolab 8000 which have built in amps but I am not sure about the 4000 series.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    all B&O speakers (Beolab) are active (recent ones, BeoVox were passive) and yes 9000 has a DIN AUX input you can hook TV sound up to.
