B F Destroyer setup...
Discussion in 'Subwoofers' started by Parmenion, May 28, 2004.
  1. Parmenion
    Parmenion
    Feb 6, 2002
    1,280
    Out there
    +64
    I have just spent the most incredibly frustrating hour reading the manual for the BFD.
    Having done that can someone explain in English exactly how this is setup? I can't even work out what the connections are between a sub and a receiver let alone how to use the feedback destroyer.
    All answers gratefully received. please reply to Mr Thickee
    c/o
    Parmenion
  2. Spearmint
    Spearmint
    Have you tried Snapbugs site?
    http://www.snapbug.ws/bfd.htm
  3. MickB
    MickB
    May 15, 2004
    538
    28
    Hanslope,Bucks
    +40
    Parmenian,
    As Spearmint says, Snapbug is the ideal site for the comprehensive guide.
    The manual supplied (in my opinion) with the BFD is next to useless, and although it looks complex in the Snapbug write-up, if you follow it through, it makes sense.
    I just got my BFD last week, and its made a huge difference!
    The connection is straightforward, just route the sub out from your receiver into input 1, and output 1 from the BFD goes to the sub.
    Happy equalising!
    :clap:
  4. Parmenion
    Parmenion
    Feb 6, 2002
    1,280
    Out there
    +64
    Many thanks for both of your replies.
    regards
    Parmenion
