azur340a
Discussion in 'Cables & Switches' started by arin, Mar 26, 2005.
  1. arin
    arin
    hey all.. i have an azur 340a amp and have a dolby digital surround sound speaker system, however the system has only a headphone jack connection or a red/black phono connection, how do i go about connecting this to my azurs speaker wire (banana) ports??.... or could i just run a phono from the record out on the amp to the subs(which has the other speakers connected to it) phono in?
    cheers
  2. Peridot
    Peridot
    Aug 24, 2004
    2,977
    Newport, South Wales
    +293
    Hi arin and welcome to the forums :).
    You can't connect the speaker outputs from the azur to the low-level input of your surround system. As you suggest, you would need to use the tape loop output on the amp, with a phono to phono interconnect.
    It would be helpful to know a bit more about what you're trying to achieve. What have you got connected to the azur and to the surround system? Have you got seperate speakers for each set-up, or are you trying to drive the surround system's speakers from the azur?
    _____________________
    Dermot
