Azur 540r connections
Discussion in 'AV Receivers & Amplifiers' started by Spud36, Sep 12, 2007.
  1. Spud36
    Spud36
    Oct 9, 2004
    138
    Portsmouth
    +4
    Hello
    I have ordered a CA Azur 540R V2 receiver but after a couple of questions to CA I believe the amp is not suitable for my needs.
    I have the following to connect
    Optical
    HD-DVD
    PS3
    SkyHD
    Coax/analogue and component for video
    DVD
    DVD recorder
    I thought it had 5 digital inputs but I understand it only has 3, either coax or optical.
    So I thought to change coax to analogue. CA have told me I will still have to swap between optical and coax so am at a loss why as I dropped using coax:confused:. Also I can only assign 1 component input.
    This is what I would like to connect
    Optical only (the three optical devices are HDMI. I have a switch so not an issue. )
    HD-DVD
    PS3
    SkyHD
    Coax or analogue and component for video
    DVD
    DVD recorder
    Is this setup possible with version 3?
    I have looked at the manual but do not trust my judgement as I read the V2 manual and between that and my ignorance in these matters I appear to have got it wrong.
    CA have told me what I can’t do but have not made any suggestions of other products of theirs which can do it which leads me to think they can’t.
    Thanks for any help
  2. dor146
    dor146
    You could connect the HD-DVD via optical to the DVD input and the DVD player via coax to the DVD input. I tried it here with 540rv2 and it seems if both devices are on the one connected with coax takes priority. So if you wanted to use the HD you would just have to make sure the dvd player was off.
  3. Spud36
    Spud36
    Oct 9, 2004
    138
    Portsmouth
    +4
    Thanks for the response.
    Thats sound like a plan. Will give it a go.
