Azur 540R and Oppo player
Discussion in 'AV Receivers & Amplifiers' started by nightmare, Mar 8, 2006.
  1. nightmare
    nightmare
    Nov 22, 2005
    59
    I'm running an oppo player with the Azur 540R V2 without the Sub. I have the option within the setup of the Oppo player to say that I DO NOT have a sub. I guess it is then splitting the Sub-channel information between the front two speakers.
    However, I also have the option to do this within the amp itself.
    My question is, using an optical cable, should I let the Oppo do this or the Amp?
    (My guess would be the amp should do it as sorting out sound is its primary function)
  2. munkyboy04
    munkyboy04
    Jan 31, 2006
    Nottingham
    hello.
    i'm also using a 540r v2 with no sub and. Ive got it set up so the amp splits the .1 through to the fronts. I tried using the dvd player to do it though and noticed no diference. so not sure if it really matters
  3. alphabet
    alphabet
    I would think that the only time any of these settings on the DVD player has an effect will be when using 6 channel direct connect between the player and amp/receiver and not when Optical or Coax is used and selected.
