Azbox
logiciel
Outstanding Member
Welcome to AVF.
It's just a channel like any other - if you can get other channels you can get it.
On a Sky receiver with a Sky World subscription you can get it activated and watch it.
HTH - Logiciel
logiciel
Outstanding Member
thfccambs
Not open unless you have full sky sub.
Needs to be activated also.
pac081273
Do not seem to be able to put in the frequency 12460 goes 12461???
can anybody else try in case I am doing somthing wrong ???
logiciel
Outstanding Member
It IS 12460 but that shouldn't make any difference.
logiciel
Outstanding Member
What is the "AZBOX Premium" and does it get every other channel on 28E?
logiciel
Outstanding Member
That's OK, so it's a satellite receiver and recorder, that ought to get the Sky 3D channel the same as any other.
The details are on the link I gave and at 3D - KingOfSat, so what happens when you try to tune it?
thfccambs
Ok , answer me this mate.
Do you have sky card in your AZ box? Do you have a full sub
on your card?
logiciel
Outstanding Member
I thought of that question but assumed the best and didn't ask it.
As the answer has now been given and it's not the best the subject can no longer be discussed.
pac081273
Do not think you understand my last post know channel would be scrambled until pay subscription but cannot even locate the channel. Do not want to pay subscription if I cannot receive the channel.
logiciel
Outstanding Member
OK, that makes your post #14 clearer and it's OK again to discuss it.
Logi
Rick1
Established Member
What the AZBOX was supposed to be ;) ;)
No Lipsyc issues though like certian DM800's I could mention :smashin:
The Az will recieve that channel fine with a correct subscription. Have you checked all the transponder details when doing a scan ? 12460H 29500 3/4 DVB-S2 (QPSK). You are just trying to scan the one transponder ? If that dosen't work which Image are you running ?
thfccambs
Like Rick say your clear it with right sub.
No lip sync problems here with dm800.LOL
Klipsch The Sevens Powered Speaker Review Coming Soon
Back
