AX5i Remote - Prestets for Sky Digital
Discussion in 'AV Receivers & Amplifiers' started by Jon, May 26, 2004.
  1. Jon
    Jon
    Does anyone know if there are presets for Sky digital on the AX5i remote, I cant find any and have programmed it using the learning function, the only problem is that i have now run out of memory, any help will be very much appreciated!
    jon
  2. Brogan
    Brogan
    Oct 9, 2003
    7,582
    Cary, North Carolina
    +482
    There are no presets - you have to program everything manually.
    I too ran out of memory so only programmed the most used buttons.
  3. Jon
    Jon
    thanks Brogan, I think the remote is great, but could do with another 7 or 8 buttons worth of memory, never mind!
    jon
  4. Brogan
    Brogan
    Oct 9, 2003
    7,582
    +482
    Yes, it's not a bad piece of kit.
    I've managed to do away with every other remote (plasma, Sky+ and DVD) but as you say, it could do with a little more memory.
    I'm hoping the next amp which will replace the AX10 will have more memory and be more user friendly (then the current AX10 remote) as that's probably what I'll get next.
  5. Jon
    Jon
    sounds good!
