AX5i - Remote Learning
Discussion in 'AV Receivers & Amplifiers' started by Jon, May 10, 2004.
  1. Jon
    Jon
    I have recently bought the above amp (as some of you already know from previous questions, thanks for all your help!!!). I have got it pretty well sorted now and am very impressed, but i am having trouble with the remote, I have got it working on all my gear now apart from one thing, my lights. The remote for the lights is a one button that if pressed and released turns on/off and if held down dims etc. when I first got the remote the first thing I did was the program the light and it worked fine first time, since then I have put presets on and it has overwritten the lights control and i cant get it to work again, I have got it turning them on and off but cant get it to dim them. I know it can be done as I already did it, but am unaware of what i did thats different. Any ideas will be very much appreciated!!!!!
    Jon
  2. Jon
    Jon
    Please, someone must have a suggestion for me!!!
    Jon
