AX5i question
Discussion in 'AV Receivers & Amplifiers' started by Stereo Steve, May 23, 2004.
  1. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    I'm thinking of getting an AX5i to go with my 757 DVD and using ilink for dvd,cd,sacd and dvd-a. I've read that you have to switch between 'movie' and 'music' modes when you swap a CD for DVD.
    Does the iLink input not have an auto function that can tell what sort of signal is coming in and switch to that eg. 2ch PCM for CD, DD or DTS for DVD's, 5.1 channel audio for DVD-A or SACD?
    Say I'm watching a DVD in DTS and want to listen to a SACD. What would I need to change?
  2. BKATZ
    BKATZ
    Aug 4, 2003
    164
    With CD, dvd,(868/A5/i-link) the amp auto-switches to the correct format (DTS/Dolby Pro Logic etc)
    So I would have thought the 757 would do the same.
    HTH
    B.
  3. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    I'm not quite sure what they were getting at but when I had a Rotel processor, I would set the DVD coax input to stereo and it would play CD's and the auto detect DD/DTS etc. The problem was that when it detected a DD2.0 signal it would switch to DPL2 and then stay in that mode when I next put a CD in. Most annoying.
    What I want is one mode where I can play CD/SACD/DVD-A /DVD and never change anything on the amp.
    By the way, have you tried SACD through the iLink and how does it compare with anaologue?
  4. BKATZ
    BKATZ
    Aug 4, 2003
    164
    Sorry not tried!
    B.
  5. kocl
    kocl
    Jan 8, 2003
    602
    PORTUGAL
    +14
    Steve, i'm using the ilink (ixos cable) between ax5i and 757, for sacd and its much better, the sound is very strong and clean.
  6. ADC
    ADC
    Jan 5, 2004
    1,881
    48
    Coventry
    +61
    Steve,
    I am using the I-link for my A-5i and my 747i and the sound is superb when listening to either DVD , SACD or DVD-Audio.
  7. Brogan
    Brogan
    Oct 9, 2003
    7,582
    Cary, North Carolina
    +482
    I use phonos for CD playback and iLINK for DVD.
    On the amp I have CD input set to DIRECT and DVD input set to MOVIE: THX.
    Not sure if this is what you mean as you will still need to select the input on the amp.
    If you use the same cable and input on the amp for both CD and DVD then the amp won't "auto-detect" the source and switch between MUSIC and MOVIE modes, you will have to do this manually.
