AX5i front speaker balance?
Discussion in 'AV Receivers & Amplifiers' started by Brogan, Dec 15, 2003.
  1. Brogan
    Brogan
    Oct 9, 2003
    7,476
    Cary, North Carolina
    +481
    Where is the balance control for the front speakers on the AX5i?
    I've searched the manual but can't find it?
  2. Brogan
    Brogan
    Oct 9, 2003
    7,476
    +481
    Come on, there are loads of AX5 owners out there and I know who you are...;)
    I find it really odd that there doesn't appear to be a balance control.:confused:
  3. Leander
    Leander
    Mar 11, 2003
    138
    Ainsdale
    +4
    Brogan,
    I've got the 1011 which I think is similar enough to say that there isn't a balance control.
    Balance just changes the volume levels of each of the front l+r speakers which on these Pioneers is done through the MCACC system as are all of the other speaker sound levels.
    Keith
  4. Brogan
    Brogan
    Oct 9, 2003
    7,476
    +481
    Thanks Leander.
    That's the conclusion I came to but couldn't quite believe it...
    It's crazy if that's the case.
    I wanted to do a simple test between 2 phono interconnects by switching the balance from left to right - with 1 interconect connected to each speaker.
    If I've got to go through the MCACC set-up screens it's not worth the bother...
