Quantcast
AX5 does not do video up-switching!?!
A
Alex-1701
Just discovered that if I put compasite in but componant out, I won't get an image.
It may not sound like much, but I think it's a big difference from the Denon 3805, which does do video up-conversion.
I think this means I'm going to go for the Denon.
Now I need to decide what DVD player to go for - I quite like the look of some of the new progressive scan HD DVD recorders, but don't how good they are.
Wasabi
And so does Yamaha 1400 & 2400.
Wasabi.
A
Alex-1701
Well I have now gone ahead and ordered the Denon, and I hope to be very happy with my decision. I have also ordered a set of PMC speakers, and the combination really out to "sing".
Still trying to make my mind up about the DVD player (probably the 2900) and projector (either Panny 500 or Z2).
A
Alex-1701
Wow ... that looks good. But I am a bit concerned about the resolution. 854 x 480 doesn't sound very good.
Nic Rhodes
you are thinking about changing your desired receiver over a cable output? Is that right? If so you have lost me here, Good quality cable a la Van damm or similar has five / six cores anyway and you therefore don't need the dreded up conversions. A single bundle can have component, SVideo and composite! Cost pence as opposed to £1k or what ever the AX is now
am I missing something here?
A
Alex-1701
Yes sure, I know it must sound a bit funny, but I have been struggling for the past few weeks trying to decide between the Denon and the Pioneer and really couldn't put a sheet of paper between them. Then I did a shootout listening to them both side by side, and slightly preffered the warmer sound of the Denon, but thought that the Pioneer had slightly more gismos, but then discovered that it didn't do video up conversion, which swung it for me. So there we are.
So now, when I change my source on the amp, I won't also have to change the input on the projector. I know it's only a small thing, but it's about the only way that I can slip them.
Nic Rhodes
Okay. so long as you know it is just a convenience thing and not a quality issue. Both receivers are great and you would probably be happy with either :)
