Quantcast
AX3 cuts out! –_speaker connections?
astro
dear all,
Having a problem. I recently added a centre speaker to my setup, a B&W which is capable of bi-wire input. I purchased QED SA Bi-wire for it to match the front two B&W speakers, and connected it up, but when i plugged it all in and played a movie disc, after a few seconds the amp switched onto standby i.e. switched itself off. I kept trying, sometimes it would play for a few seconds, but when it seemed to get louder this would trigger it to switch itself off.
I messed about with the settings/connections, and noticed that if i take two of the bi-wire connections out of the centre it sorts it out, but should this be the case, after all, the centre is bi-wirable?
How and why is this happening, and should i just leave it the way it is. I am finding the centre a bit 'bass-ey'.
cheers
Astro
T
TheBlueVoice
I think the bi-amp option is meant only for the front left/right pair...
I take it that you selected the bi-amp option in the setup menu?
This causes the the front left/right signals to be sent to 2 amps each.
astro
I'm trying to bi-wire the centre (B&W LCR60).
The front two (B&W CDM 1NT's) have QED Silver ann Bi Wire cable.
I mean the centre connection terminals, which are bi-wire capable.
Any ideas?
Astro
Q
Quatermass
Be worth checking whether any strands of the speaker cables are touching each other at the connectors (i.e. “shorting out”). This could cause the amp to go into standby.
