AX3 and kht 1005
Discussion in 'AV Receivers & Amplifiers' started by philthyanimal, Oct 13, 2003.
  1. philthyanimal
    philthyanimal
    I seem to have narrowed my choice down(mainly due to budget and cosmetics), to the vsx ax3 and the kef kht 1005 speakers.
    Before i actually hand over the cash can any one give me any reasons as to why i should not buy these, or give me some alternatives with reasons.
  2. Big Adam
    Big Adam
    May 7, 2003
    527
    Peterborough
    +4
    Have you auditioned them? If not, there's point #1 for you.
    Secondly, is your room/environment so small that you need the super compactness of the 1005 system. If you can afford a slightly bigger speaker, go with the 2005.2 system.
    Only £150 more than the 1005 set (if you can get to Creative Audio or somewhere that will price match them) but the difference is well worth it.
    Big A
  3. philthyanimal
    philthyanimal
    the living room is very small, its about 12 ft by 12 ft square.
    Also the speakers are costing me £315 (not a bad price i thought).
    can't really go much above that(have been offered the 2005 for £370, but their in black)
