P
philthyanimal
I've just bought a set of gold plugs, puresonic or something. Anyway, I think i've made a big mistake as it seems the AX3 wont take them, as in the manual it only gives instructions on fitting bare speaker wire into it.
Can someone cofirm that this is the case.
I want to be able to return them if they're no use.
Thanks.
Thanks.
