Away mode - Anyone get it working ??
Discussion in 'Microsoft Windows' started by mark.carline, Oct 19, 2005.
  1. mark.carline
    mark.carline
    Jan 15, 2004
    2,132
    Chester, Cheshire
    +121
    Can anyone comment on this new away mode feature yet ?
    http://support.microsoft.com/default.aspx?scid=kb;en-us;902437
    Has microsoft released it as part of "windows update" / update 2 that we have all installed ??
    Does anyone know if the OEM version includes this functionality ?
    Is anyone using the OEM version of update 2 that can comment if its in there??
    I would really love to be able to leave my PC on 24x7 and still able to use scheduled recordings / Webguide3 remotly (via tinternet) but dont really like the idea of using loads of power.
    Does anyone have this working that can have a look in their BIOS to see what this new "away mode" feature looks like??
    Thanks!
  2. ACMErubberDuck
    ACMErubberDuck
    May 26, 2005
    123
    Dublin
    I think this needs future hardware or a BIOS update before it will work. Rollup 2 just adds support for this feature in the futue.
  3. Werner
    Werner
    correct. without motherboard vendor support, away mode isnt available. Only oem's can install it, and only if the board supports away mode, so you may as well forget it exists.
