Question Avr600 to Samsung oneconnect
stevetomlin
I have an Arcam AVR600 that I've just had serviced and repaired at Arcam. Works beautifully with CD as before, but I can't now get TV audio through the receiver.
I had an optical cable from the Samsung Oneconnect to the optical AV input on the 600, and an HDMI from ARC on the oneconnect to HDMI out 1 before it went for repair and it worked, now, whatever cables I try, I get no audio. Any advice? Please remember I am not an expert in any sense, so simple ideas please!
D
Deleted member 39241
Probably the unit got factory reset during the repair. You need to go through the menus again and make sure everything is switched on for ARC to work. And also assign the audio to use optical for the input where you have the optical cable connected.
stevetomlin
Thanks, I thought it may have been reset. I can't get the menu on the TV though. I'm missing something obvious, but it's driving me crazy.
D
I am just looking at a picture of the back of the AVR600 and none of the HDMI outputs are labelled as ARC, so maybe it doesn't have Audio Return Channel? In which case the optical cable will have to do the job.
To get the onscreen menu up, connect an HDMI cable from HDMI output 1 on the Arcam to any HDMI input on the TV. Make sure the TV is switched to that HDMI input, then on the Arcam remote press amp then menu,
stevetomlin
Thanks for that. There's no ARC on the AVR, but it was working before on HDMI OUT 1 to the oneconnect. I'll try the menus.
