AVR3806 vs. AVC-A11SR
Discussion in 'AV Receivers & Amplifiers' started by HarryW, Oct 15, 2005.
  1. HarryW
    HarryW
    Hello All,
    I am about to place an order for a Denon AVR 3806. The salesman in the shop has now tried to convince me that i should rather go for an AVC-A11SR as he could give this to me for the same price? I assume it's probably second hand. Is the AVC-A11SR a much better amp/receiver or should i just stick to my original choice? Thanks
  2. Tony8377
    Tony8377
    Aug 19, 2004
    954
    Essex
    +4
    Depends what you want? If it Pro Logic IIx, HDMI switching, very good auto setup (I presume) then go for the 3806. If it's better amplification then go for the A11SR
