AVR350 - do I need software upgrade ?
Discussion in 'AV Receivers & Amplifiers' started by morsimon, Jan 10, 2008.
Tags:
  1. morsimon
    morsimon
    Feb 4, 2007
    156
    Hertfordshire
    +3
    My AVR350 is using software version 3.39 - from the info that Crustyloafer has kindly provided on this site it would appear to me that there is little or nothing to be gained from going for the upgrade at the moment. This assumes that I have understood the Release Notes correctly which is definitely not a given ! Could someone with greater knowledge please confirm that my understanding is correct ?
    Many thanks, as always
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,577
    Edinburgh
    +1,269
    If you don't see anything in the release notes that you feel would benefit you in any way then just leave it alone.
  3. morsimon
    morsimon
    Feb 4, 2007
    156
    Hertfordshire
    +3
    Crusty
    Thanks - I found the Release Notes a little confusing as there is nothing stating these are for the AVR350 - I am assuming that it is only a couple of items on the last page that actually apply to my machine ie -
    Software 3.39 to 3.48
    1. Additional RS232 Commands added.
    2. MCH input now assignable to HDMI Input
    3. Zone 2 Volume Bug Fixed.
    If the above is all that would be updated then I am happy to leave it alone. However, is my interpretation correct ?
  4. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,577
    Edinburgh
    +1,269
    Yes.
