Jabberwocky
Having upgraded from an AVR100 to the above I find out the connections on my speaker cables won't fit the connectors on the 350, according to the manual I either just crimp the cable under the nut or fit spade connectors, are there any connectors which push into the speaker screws on the back of the 350 ???
Also which is a better cable to use, an s video lead or scart lead?
