AVR350 broken?
Discussion in 'AV Receivers & Amplifiers' started by miko0815, Dec 20, 2006.
Tags:
  1. miko0815
    miko0815
    I got my AVR350 just yesterday and I'm really impressed by the audio performance. But I noticed one thing which might be an issue.
    When I change the mode (e.g. from Stereo to PLII or DTS) I can hear a pop in the loudspeakers. I wouldn't expect that this is a "feature" on a high end device.
    Does anybody else noticed this issue as well?
    Thanks in advance,
    Michael
  2. Mr X
    Mr X
    Aug 8, 2006
    6,941
    3
    +2,551
    Don't get any "pop" on mine at all, sorry.
  3. scouse258
    scouse258
    May 22, 2005
    413
    Newcastle
    +5
    what DVD player/ kit are you using?
  4. miko0815
    miko0815
    I have a Marantz DV6200 connected at the moment, but awaiting the delivery of my DV137 within the next days.
    I'm not sure if the DVD is the root cause, because I hear it when I watch TV as well.
  5. LOXjet
    LOXjet
    Sep 2, 2006
    478
    43
    +126
    This is by design it seems.
    I asked about this when I bought my first Arcam receiver (also an AVR350).
    Apparently to gain a small amount of audio quality, Arcam leave out a filter (or switch) or something that means you hear the clicking noise.
  6. Mofar
    Mofar
    Apr 12, 2005
    34
    +4
    If it is a soft pop, then it's common. I have had an AVR300 which made these pop sounds and my new AVR350 does exactly the same. Contacted the dealer who said that it is why Arcam sounds so good: no relais in the signal path. The same pop sounds can be heard when changing source. But when the pop is loud ........
  7. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,577
    Edinburgh
    +1,269
    Vasquez and Mofar are both correct on this one. They have deliberatey done this in order to maintain the highest quality signal path.
  8. Mr X
    Mr X
    Aug 8, 2006
    6,941
    3
    +2,551
    Strange that I don't get it on mine. All I get is slight silence from my B&W XT's. The only time I get it is when using headphones, then it's very noticable.
  9. miko0815
    miko0815
    It's just a soft pop, so I'm not concerned that it will damage my loudspeakers. As I said the sound is really amazing, so it looks like that I have to live with it.
  10. killer10971
    killer10971
    Dec 29, 2004
    1,120
    +36
    yep mine does the same with my m&k xenon and i have posted several times on here as i thought it was a fault with my 350
    as explained in the above posts , they dont put a muting resistor in the signal path due to sound degradation , i used to hear mine all the time as i was listening for it , now i barely hear it
    cheers
  11. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,577
    Edinburgh
    +1,269
    The B&W XT series are very low sensitivity speakers, and are therefore less likely to accentuate this design feature.
  12. AL_T
    AL_T
    Jul 27, 2003
    27
    Coventry
    +5
    No 'pops' with my B&W's .
  13. chantrys
    chantrys
    Apr 11, 2005
    274
    +9
    I also get a soft to medium pop with my Quads.
  14. killer10971
    killer10971
    Dec 29, 2004
    1,120
    +36
    compared my m&k xenon against kef eggs and i had to put my head next to the kefs , the m&ks i can hear from 2-3 metres away
    cheers
