AVR30R problem
Discussion in 'AV Receivers & Amplifiers' started by Juerg, Mar 8, 2006.
Tags:
  1. Juerg
    Juerg
    Hi all,
    My AVR30R suffers from the following problem:
    The right channel does not work anymore when it was in standby for a couple of hours. I have to unplug and replug the device from power to make it work again. When I just put it in standby and activate it after a couple of minutes, it does not have this problem.
    Question, before I send it to repair, I'd like to reset the device. Can somebody tell me how to do this.
    If this does not work, who can repair TAG devices? I am living in Switzerland and the information I got so far is not very promising.
    Thanks a lot
    Jürg
  2. guidob
    guidob
    Unplug the power. Press "Analog", "Video" and "Normal" at the same time. Plug the power and when it says "DISP EE" hit "Display".
  3. Juerg
    Juerg
    Thanks,
    I just discovered the Audiolab 8000AV. I seems to be the same as the AV30R. Is that right? Would Audiolab fix broken AV30Rs?
    Jürg
  4. laalves
    laalves
    Feb 6, 2005
    529
    Cascais
    +8
    Yes to all of your questions.... :D
    Luis
  5. Juerg
    Juerg
    So there is hope out there...
  6. stef1777
    stef1777
    Jan 4, 2006
    121
    Does this "reset" the user config to default?
    Stef...
  7. Juerg
    Juerg
    Yes it does, just tried it out.
