Avr300
Discussion in 'AV Receivers & Amplifiers' started by Jesse350, May 22, 2004.
Tags:
  1. Jesse350
    Jesse350
    I would like to know if I buy an AVR300 receiver before I decide on and buy a new display and universal player, could I hook it up to my present stereo components. I am having a difficult time on deciding exactly what I want. My emphasis will be on classical music with movies secondary. I do have an excellent stereo system now (including B&W 802 Nautilus speakers and ten year old Krell amp and preamp. Anyway, the question is, should I wait or not? Thanks for any advice.
    Jesse
  2. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    The AVR300 has numerous inputs for stereo components except turntable phono, although you can attach an outboard phono reamp for that. You can also configure the AVR300 with just a single pair of stereo speakers via the setup menu. There's also a Stereo Direct mode that allows you to play analog stereo sources without any DSP processing to give you the best audio quality.
    I can't really tell you whether or not you should get it. I have one a like it very much, but I use it almost entirely for movies in a 7.1 setup.
    Dean
  3. Jim_R
    Jim_R
    Dean, where in the USA do you live?
  4. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    Jim. I'm reluctant to provide much detail about my whereabouts, but if you tell me why you ask, I might be able to accomodate a reasonable answer.
    Dean
  5. Jim_R
    Jim_R
    I live in Michigan, and was wondering where you purchased your AVR300.
  6. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    Music For Pleasure in Missouri. Are you trying to get one? I had mine preordered, so got one of the first units, but I believe they're still in short supply while Arcam is working to fill orders and ramp up production. But you might check with Audiophile Systems to see if there are dealers near you with availability. You can get a dealer list straight off their web site.
    regards, and happy hunting...
    Dean
