AVR300 - Zone 2 Input Sensitivity
Discussion in 'AV Receivers & Amplifiers' started by LameBolus, Jul 27, 2004.
Tags:
  1. LameBolus
    LameBolus
    I have a XM Radio (Satellite Radio, Delpi SkyFi Home Version) that i needed to decrease the sensitivity to 0.5 (low) to match my DVD and TV (Satellite) output for Zone1. When I run Zone 2, the sound is pretty low in comparison to the dvd or sat. Is there a different area to change the input sensitivity for Z2? I couldn't find one. Should the sensitivity be a global change? Both the DVD and TV are equal in sound level when switching Z2 sources.
    Thanks,
    John
  2. ANDY_DUTTON
    ANDY_DUTTON
    Aug 27, 2002
    498
    28
    Cambridge
    +87
    Hi John,
    Sorry, there is no input sensitivity setting for the zone 2 inputs you will have to adjust the volume control.
    Regards,
    Andrew
