AVR300 without front speakers
Discussion in 'Arcam Owners' Forum' started by ramallo, Aug 10, 2005.
  1. ramallo
    ramallo
    Hello,
    Can I use the AVR300 without front speakers?. The reason is because I have a very nice tube integrated amplifier (Manley Stingray), and for me sounding better with stereo sources than the AVR300, but I'm very afraid by leave it working without load. :confused:
    Best Regards
  2. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,117
    83
    Over the Hill & Far Away
    +119
    Should be fine.. is there not a option to set which speakers are used in the OSD anyhow ?
  3. ramallo
    ramallo
    Hello Matt,
    Thank you for your help. The OSD don't have an option for disconnect the front speakers (Only small or large). :)
    Best Regards
  4. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,523
    Edinburgh
    +1,243
    Shoudn't cause any problems at all. I run my AVR300 via the preouts to a separate power map for the fronts and it all works fine, in fact that's the very reason the preouts are there in the first place.
